주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2007년 Dremel에서 제조한 기본 배터리 구동식 로터리 툴입니다.
What does the blinking light mean?
I noticed that the green light is blinking. Is something wrong with the Dremel?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
What if it never stops blinking??
의
댓글 달기
답변 2개
선택된 해법
Don't worry - The blinking doesn't mean that there is an error. The green LED on the charger indicated that you properly plugged the battery pack into it. While it is charging, it will continue blinking. When charging is complete, the light will stay steady green.
이 답변이 도움이 되었나요?
점수 12
댓글 7개:
Sweet I was wondering the same thing, thank you interwebs.
의
Same here..........
의
Mine keeps on blinking and when I go to use it, it has no power to operate my Mini Mite
의
Mine blinks when I first put the battery in..5 min later its steady green and of course it is NOT charged. Waiting to hear back from Dremel.
의
I have two lighs. one steady red and other is flasing green float. what does float mean
의
댓글 2개 더보기
댓글 달기
7700/708 battery. green light has been "charging" aka "flashing of 18+ hours and battery is dry as a bone, no charge.
This @#%$#@^ 7700 has LESS than 18 hours of use in 4+ years. Battery is stores away from charger (separate rooms). does the battery just die from being lonely?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Same issue as @ralph78 and @rroby. Charger LED just keep flashing green. I have two batteries - does the same with both. The flashing seems to be somewhat faster than normal charging indicator. It never goes to steady green (indicating a fully charged battery) and neither battery has any power. I use the dremel infrequently so have always charged a battery before each use. I'm thinking it must be a charger issue rather than a battery problem? Do I need a new charger or have both batteries died?
의
댓글 달기
답변을 추가하세요
Kat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 100
전체 시간: 41,147
