Why is my device not charging?
I connect my device to the USB cable and never charges unless I hold the cable.
좋은 질문입니까?
좋은 질문입니까?
Hi Daniel,
This problem sounds like you have a faulty MicroUSB port on your Flip 2. On occasion, the Flip 2's MicroUSB port may become dislodged, causing issues in charging or connectivity. You can try soldering the MicroUSB port back onto the circuit board. You can visit our guide here for more information on the repair of the port.
이 답변이 도움이 되었나요?
it sounds like the charge port is broken if it needs to be in a certain position to work
이 답변이 도움이 되었나요?
I charge my flip 2 & it doesn't charge.
Yes I have to position it a certain way but still don't get full charge & how much would it cost me to get this repaired and where can I go.
이 답변이 도움이 되었나요?
Hi Veronica,
Did you solve the problem already and if yes, diy or specialist repair? I have the same problem.
Erwin
I am experiencing the same problem with my speaker in that it wont charge. If you fiddle with the cable the lights will flash briefly and then goes off. How can this be fixed as I like the quality of the speaker. Assistsnce will be appreciated.
I have had that problem over the past decade with various Bluetooth speakers & headphones that require recharging. I find that the manufacture of the recharge ports and cords is anything but standard. By hanging onto every charger cord I get with products and any that someone has thrown away (and buying a few for less than $10), I usually find a charger that will work for any particular item.
이 답변이 도움이 되었나요?
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 4,010
