주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 7월 28일에 출시된 Samsung Galaxy S5 mini는 8MP 후면 카메라, 720p 화면, 지문 스캐너 및 방수 기능이 있는 휴대 전화입니다. 이 휴대폰은 이전 모델 Galaxy S5에서 개선된 더 큰 화면, 늘어난 배터리 사용 시간 및 카메라가 있습니다.
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
의
πως το διορθωνουμε αυτο το ποβλημα?
의
댓글 달기
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
how do i fix this problem?
의
by flashing it with Odin
의
댓글 달기
답변을 추가하세요
tonyknors 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 28
전체 시간: 2,232
