Why is my device not printing correctly?
When I try to print out a label, the label maker doesn't print correctly.
좋은 질문입니까?
좋은 질문입니까?
Check to make sure nothing is obstructing the printing area, then make sure your cassette inside the label maker is correctly aligned and pushed all the way down into the compartment. If problem persists, follow the link below to the troubleshooting page.
이 답변이 도움이 되었나요?
For others that have this issue, I was having the issue as well. For me, it was weak batteries causing the ribbon not to print/advance even though the winding motor was turning.
I tested all batteries with a battery tester! All batteries were well up into the green! Just for the heck of it I changed all the batteries! Voila! Problem solved, just as Dave stated. Funny how the unit needs so much power! I'll save the original batteries for another use!
in absolute disbelieve worked for me too!! even though I changed the battery I switched from Kirkland brand to Duracell and I have printed labels. I had exact the same situation as Dave
@Dave Pope It finally came alive for me after trying my 3rd set of brand new batteries. Thank you for the post.
I had the same problem. Replaced the batteries. Works fine. Like others have said why does it need new if not almost new batteries to print. Oh well.
Home & Hobby III P-touch printer stopped printing. Motor works.
이 답변이 도움이 되었나요?
I have it hooked up to a power pack and it's not printing. It just prints the sticker. ??????
so the battery thing is not working for me... there are still no letters printing on the tape and by this point now i almsot out of tape just trouble shooting the darn device.
이 답변이 도움이 되었나요?
The print head is not moving but the sprocket does when I press the insertion detection https://help.dymo.com/s/article/How-do-I...
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 15
지난 30일: 66
전체 시간: 91,610
댓글 2개
I have this printer and when i am getting prints labels come little bit yellow to brown colored repeatedly/exactly at the same time. What could be the problem?
Irshad Meyo 의
the print is not legible. and I have the LetraTag
sheryl wesolowski 의
