주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 11월에 출시된 Lenovo G 시리즈 보급형 노트북.
My machine won't regulate processor thermal heat
Hi i'm Leslie,
Ive got a lenovo g580, i3 with 8GB RAM running on Windows 10 (v1511) ,
my main problem is the Processor Thermal.
I tested my machine with the Intel Processor Diagnostic Tool 64bit latest version, managed to pass everything else but failed with the following error :
Entering run forever
1 degrees C below maximum
Test Result - FAIL
Expected Greater than 1 degrees below max
Received 1 degrees below max
Test FAILED
Please check your Processor Thermal Solution
Kindly help us with a solution for the problem because its been making my machine shut down unsuspectedly without notifying. This has caused instability when i'm working throughout the day.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Is the CPU fan running? Are the vents clear and unobstructed? Use Task Manager to see what % the CPU is running at. If high % and you are not doing much on the laptop, check what applications or processes are using the CPU the most and why
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Leslie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 541
