주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenwood Chef A701A는 Kenwood에서 출시한 스탠드형 푸드 믹서입니다.
Drive belt keeps coming off
I have re-assembled my Kenwood Chef (it actually might be an A901 but they are very similar) after replacing caps and resistor.
The drive belt wants to come off. It has burnt channels in the top cover!
Some forum answers have suggested that the motor is turning in the wrong direction.
Why is the belt coming off and what do I need to do to fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
You may need a new belt . If the belt has heated and burnt on an edge it can cause the belt to go out of round . remove the belt and hang it from your finger . Does the belt hang straight or does it bend to one side if so it needs to be replaced . If this isnt the problem check the alignment of the pullies. make sure they align straight . if this is fine then make sure the belt is tight enough. Hope this helps
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The tension on the belt is adjusted using the three screws/nylon motor mounting bushes which secure the motor to the casing. The belt should be slightly loose - i.e. you should be able to squeeze it slightly with your fingers where it comes away from the small pulley on top of the motor. Be careful not to over-tighten the motor screws as it is possible to strip the threads in the top of the casing.
Most importantly, there should be a white plastic washer which fits tightly on the top of the small motor pulley once the belt is on. This stops the belt riding off and damaging the top cover.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Ross Musumeci 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 22
전체 시간: 1,754
