주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dremel 8220 가변 속도 무선 로터리 툴은 모든 Dremel 무선 로터리 툴 중에서 최고의 성능을 자랑합니다. 출시일: 2012년 6월 22일
Why is my Dremel overheating?
So I've been using this device for about 3 hours and within that time I needed to charge the battery. When i did that I used it again right after and while I was using it, the device seemed very hot, the battery specifically. What's wrong with my device?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
My flex shaft is getting hot, not the actual Dremel. The flex spring is very hot after about 10 minutes of operation.
의
댓글 달기
답변 3개
선택된 해법
1. You used the device for a long period of time and the battery really got hot, just turn it off and use it again after 20-30 min.
2. Your fan that cools the device might be broken. The fan is what cools the device and stops it from overheating. If broken just remove the fan and add a new one in.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
I live in an Apartment- I found out on mine, It was my problem… I was runing it at to low of Speed. To keep the sound down….. End of my motor.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
They use a TO-220 MOSFET inside with a terribly small heatsink and a small glueless mating surface between the MOSFET and the heatsink with a loose rivet. The MOSFET can get too hot and blow (small puff of smoke, sparks…etc.) I just ran into this myself. I’m going to have to desolder the MOSFET(s, there is a second one beside the TO-220) and put them on a better heatsink, properly mated as well. …Conveniently a month after the warranty expires.
*Edit* For anyone needing to replace the electronic assembly inside, the part number is 2610005464.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Meeley Bien Aime 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 36
전체 시간: 9,036
