주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Transformer Pad TF103C는 2014년 6월에 출시된 10.1인치 Android 하이브리드 태블릿입니다. 와이파이(Wi-Fi) 기능을 갖추고 있으며, 엔터테인먼트 용도로 특화된 기기입니다.
Why won't tablet screen ROTATE?
My tf103c screen won't rOtate and have:-) No sound can aNyone :-)help me .
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Hi,
With regards to screen rotate have you checked that the following setting is ticked?
Settings > Screen > Auto Rotate.
Also the screen won't rotate if the keyboard is docked.
With sound, have you tried using headphones to see if there is sound?
Update (04/17/2016)
Hi,
Try the following.
Use the tablet's backup feature to backup your tablet.
Then reset your tablet using the factory data reset feature.
Once your tablet has been reset, see if the touchscreen and the sound work properly.
If so it may be that either a software glitch or a downloaded app was causing the problem.
Restore your tablet with the backup you made, using the tablet's restore feature.
See if the touchscreen and the sound still work.
If so, the reset has fixed whatever glitch was causing the problem
If not, perhaps a downloaded app is causing the problem.
The trick is now to find out which one.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
The auto rotate is on an I've tried headphone jack still no sound
의
I'll give it a try thanks
의
댓글 달기
still can't rotate..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ericjnash 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 12,814
