주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
Are Torx Security bits compatible with non-security bits?
I am looking to upgrade my wife's old Macbook Pro with an SSD, following this guide: MacBook Pro 13" 유니바디 Mid 2010 하드 드라이브 교체
It says we need a T6 Torx screwdriver. I thought it was weird that the driver kits being sold by iFixIt wouldn't include anything higher than T5 for non-security Torx bits, but then I saw the following on this page: TR6 Torx Security Screwdriver
"Security drilling on this driver makes sure that you won't be stopped by anything, even though this driver still works great in non-security T6 screws as well."
So, can anyone confirm if Torx Security bits are compatible with Torx non-security bits, and does this hold true for all Torx bit sizes?
Precision fixed blade screwdriver engineered by iFixit. 이미지
제품
$5.99
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 달기
답변 2개
선택된 해법
The difference between security torx and standard torx is the hole drilled in the center, this allows the driver to slip over the pin located on the security screws. Otherwise they are identical sizes.
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
is just the hole the difference? both share the same sizes?
의
댓글 달기
가장 유용한 답변
Of course they are, all it is, is an extra hole.
이 답변이 도움이 되었나요?
점수 7
댓글 달기
답변을 추가하세요
Help Computer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 25,302
