주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
iPhone 5 Stuck In Bootloop... Any Help?
My iPhone 5 was given to me by a friend and it is in a boot loop. I tried restoring but i get error 9 and my phone is only recognized by the computer in recovery/DFU mode. At first, I thought it was because of the battery, so i took a 100% charged battery from another iPhone 5 and installed it but it still boot loops. Now, I don't know if its because of a chip or the dock connector. Any Suggestions? Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hey Mojo, here are some things I'd recommend you try:
Different USB Cable
The iTunes error 9 usually occurs when the device is unplugged during the restoration process. Replace your lightning USB cable and try again.
Update iTunes
Reinstall iTunes or update it.
Different Computer
I've been through this situation before where I installed a faulty jailbreak tweak and bricked my device. I tried to install a new version of iTunes on my new computer and it successfully restored my device.
Disassemble and Reassemble
Disassemble and reassemble the device. Maybe you missed something. Follow this guide on battery replacement for instructions.
Different Battery
Purchase a different battery and try it with that. I doubt there is an issue with the battery because your device boots up.
Logic Board Damaged
Your logic board might have a damaged battery connector which is causing this bootloop. Here is the guide for replacing this. You can replace the battery connector itself on the logic board, but that would require soldering.
-Let me know how it goes.
iPhone 5 Battery 이미지
상품
iPhone 5 Battery
$29.99
안내서
How to replace your iPhone 5 battery
난이도:
운영
15 minutes - 1 hour
iPhone 5 Logic Board 이미지
안내서
iPhone 5 Logic Board Replacement
난이도:
운영
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 10개:
Thank you for answering sir. I appreciate it. I think it gives an error 9 because the iphone is only recognized when in recovery/DFU mode, so when itunes tries to install the firmware it shuts off and therefore disconnects, but i may be wrong. i will try another computer and will reinstall itunes right now. Im using a different cable too. Thanks again!
No problem! I'm glad I can help :)
-If the phone doesn't restore then there might be an issue with your battery connector on the logic board. But before you replace it, disassemble and reassemble your device first.
When you say disassemble and reassemble my device, your saying to take out all the parts and put them back right? Just clarifying.
Yes, because before you do any replacements, it's important to check if any mistake was made and confirm if anything actually needs replacements.
Alright thank you. I may inbox you if i have any more questions.
댓글 5개 더보기
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 154
