주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2001년에 출시된 닌텐도 Game Boy Advance입니다. 수리 과정에서 열을 가할 필요가 없으며 일반적인 수리 도구만 있으면 됩니다.
Gameboy Advance Sound Issues
Does anyone have any suggestions for fixing sound issues with the original GBA? The sound through the speaker and headphones is crackly at best and cuts out or is very very faint most of the time. I thought it was just the speaker at fault and switched that out but it's still the same.
Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
I've watched a youtube video by RetroGameTech that went through the process of restoring a destroyed Japanese Sega master drive. He found that some of the board controllers (caps/resistors/etc) were causing sound issues. Another video of a Neo Geo board (same guy) had a bad card slot with damaged pins that was distorting the sound. You'll want to locate those parts/pins and start there to see what the issue may be since replacing the speaker didn't help (that was my first idea).
의
I'll have to find that one with the Sega on Martin's channel, I thought I'd watched all his repair videos! I also had someone else suggest bad caps or a bad headphone jack. I'll try cleaning everything up and inspecting the solder joints and so on first. Didn't think of the card slot pins though, I'll check that out too. Thanks.
의
댓글 달기
답변 2개
선택된 해법
In the end, it was just a dirty headphone jack. I cleaned the headphone jack with a cotton bud and some rubbing alcohol and that seemed to do the trick. Thanks to @thisdoesnotcomp on twitter for the suggestion.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
More than likely the issue will be with capacitors. They go bad after time and need to be replaced.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
martin8777 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 73
전체 시간: 11,173
