주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
Note 4 from Verizon stocks in a boot loop
Hello!
I have a SM-N910V to fix a boot loop. I made a Odin flash with the last firmware and previous firmwares but when flashing ends it reboot and it stocks in a boot loop on Galaxy Note 4 logo and the upper left side of the screen shows a blue "recovery booting" and vibrate.
Anyone have a suggestion?
Thank you
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
선택된 해법
So it won't allow you to boot recovery mode even after a firmware flash? I'm puzzled. Try having the phone off then hold the Power + Volume Up and Home button until you get the blue 'Recovery Booting' text and wait for it to boot recovery. Should take around 10-20 seconds.
Then you will have to do a wipe data / factory reset most likely in order to fix this boot loop issue. Make sure you are running latest firmware and not previous ones as this can cause issues if using too old of firmware.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I do every thing you suggest and it stocks in a boot loop and it won't allow to recovery mode....
의
댓글 달기
So, try the reset sequence when the phone is plugged in. After reading the last comment about the battery issue I thought maybe my battery was just messed up. Turns out I was right. I was able to reset and reboot while plugged in. I'll grab a new battery tomorrow…
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I solved this problem by replacing the “no name equivalent” battery I was using with a SAMSUNG battery. The no name battery measured 4.3 volts…..it’s supposed to be 3.8 volts.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ruben Lopes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 17
전체 시간: 5,698
