주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Satellite C660은 Toshiba가 2010년경에 출시한 노트북 시리즈입니다. 15.6인치 화면과 다양한 Intel 프로세서를 탑재하고 있습니다.
failing to boot , black screen
Hi there i have a toshiba satellite c660d im having trouble with. was working fine shut down for a few weeks then tried to boot but its not booting, the fan spins up for a couple seconds and shuts down and leaves a black screen. hard drive and ram are fine tried in another laptop. im comfortable in striping down the laptop and computers but im stumped on this one. ive dissembled the laptop and checked all connections and ports cleans fan and everything inside but still no luck. ive tried the remove battery and boot from mains power and the shift f8 and the 0 but still no luck. i think its either a screen error as ive yet to try an external monitor but i have check all connections on it and there fine or something is shorting out the board. any help or advice would be grateful.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
가장 유용한 답변
For some reason it is boot cycling witch means something in the hardware side in not right... Try booting it without anything not needed to boot like the HDD, wifi card and such, this is hard to diagnose in laptops but you have to find out what is wrong by the prossesser of elimination (that is why it is hard to do with a laptop, most of it can't be take out) there is a good chance you may not be able to fix it and will have to get a new computer but on the bright side it looks like the HDD is OK as you said it worked in another machine so... All the stuffs is still there...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you hear a constant *beep*, try waiting for this beep to end. This worked for my computer!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
graeme 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 45
전체 시간: 2,634
