주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cuisinart Griddler GR-4N은 컨택트 그릴, 파니니 프레스, 전체 그릴, 전체 그리들, 반 그리들 등 다섯 가지 용도로 사용할 수 있는 주방 가전입니다.
Why doesn't the indication light turn on?
The indication light has stopped turning on even when the device is on and the cooking surfaces are in use. Does this mean the heating temperatures are affected or is it just the light which is an issue and how do I address this problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
The indication light on the cooking knob does not turn green until desired temperature is reached. If light does not turn on there is a problem with the LED light, either the light needs to be replaced or simply internally reattached. Follow link to fix LED Cuisinart Griddler GR-4N Troubleshooting
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It is neither a light or a connection
It controlled by the board on the far left side. You have temp sensor in the black metal spring in the middle of the unit. That sends a signal to the board
There is a small ic that controls a relay that is at the end of the pc board
If you are able to heat up the solder connections that may resolve the issue
Good luck if not as they don't sell this important part
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kayla Londono 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 30
전체 시간: 5,026
