주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
Upgrade Internal Hard Drive
Hi,
I have purchased an iMac (Retina 5K, 27-inch, Late 2015) - Very basic one with default 1TB WD HD. No fusion, no flash storage.
I'm thinking to replace the 1TB WD HD with an SSD from OWC. I also heard the PCIe slot is unpopulated in my iMac. Anyone know if I can purchase any flash stick to plug in (if it fits)? The original purchase is not Fusion so will it show 2 SSD drives in the OS?
Beside the flash storage, what is this PCIe port capable of? Does it work with any PCIe components (cards) for other usage purposes?
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Here's the full specs of your system: iMac 27" 3.3 GHz i5 5K display (Late 2015)
댓글 달기
답변 1개
선택된 해법
PCIe connector in your system is a PCIe 2.0 x 4 Lane NVM Express interface. Sadly it takes a proprietary Apple SSD unit. The SSD blade drives Apple offered was either a 128 GB, 256 GB, 512 GB or 1TB.
The larger sized SSD's are hard to come by for sale on the open market, you will likely need to order a spare unit from an Apple authorized servicer, I worn you it will be expensive! The other option here is seeing if the just released 3rd party SSD from OWC will work in your system.
As for swapping out your current HD for a SSD. While that is possible you will need to get an adapter frame as your current drive is 3.5" while the SSD is 2.5". In addition your system leverages a builtin thermal sensor within the HD. You'll need to replace it with this adapter from OWC: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later in addition to the SATA SSD unit.
The newer Thin series systems are much harder to open and you do run the risk of damaging the display assembly if you don't follow the IFIXIT guide: iMac Intel 27" Retina 5K Display Hard Drive Replacement or if you dare: iMac Intel 27" Retina 5K Display Blade SSD Replacement
Remember the PCIe blade interface is much faster than the SATA III interface and the Thunderbolt II interface is also faster than the internal SATA port.
Frankly, I would not take the risk here and besides, the larger SATA SSD's are still quite expensive! I would go for an external Thunderbolt 2 RAID unit like this one: ThunderBay 4 Mini. It will offer better performance than the SATA SSD and offers less risk.
iMac Intel 27" Retina 5K Display 하드 드라이브 이미지
안내서
iMac Intel 27" Retina 5K Display 하드 드라이브 교체
난이도:
조정
1 - 2 hours
iMac Intel 27" Retina 5K Display Blade SSD 이미지
안내서
난이도:
어려움
2 hours
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 721
