주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Infant Optics, Inc.에서 제조한 아기 모니터입니다. DXR-8은 3.5인치 화면, 온도 센서, 야간 투시 기능 및 교체 가능한 렌즈 시스템을 갖추고 있습니다.
Power button on monitor stuck
The power button on the infant optics DXR-8 is stuck. Is there a way to fix this so we do not have to buy a new one?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
선택된 해법
Just fixed mine today because ours was stuck as well and the slightest tap to the button would turn it on or off.
What I did was:
1. Follow the dis-assembly guide on this site. I used a small pocket knife to separate the adhesive front plate.
2. Take apart a ball point pen that has a spring in it.
3. Cut a quarter of the spring off.
4. Compress the spring and place it so the less coiled end goes around the digital push button switch nub on the main board. The spring end *should* be around the nub not really pressing on it.
5. Place the plastic button on top of the spring. Might take a little finagling to get it to stay and be center.
6. Reassemble!
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
We tried this and it worked. Thanks for providing!
의 공유
Genius, worked like a charm. Thank you!
의 공유
Does anyone have any experience with the actual switch on the motherboard malfunctioning? I took it apart but the electrical switch seems to be finicky (I can't get it to function like I'd expect).
의 공유
where is the dis-assembly guide? I cannot seem to find it.
의 공유
댓글 달기
Try removing and re-inserting the battery, that somehow fixed our issue of non-functional power button
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mitch Abby Wilson Minnix 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 66
전체 시간: 21,109
