주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
replacement video card for desktop
I need to replace the video card for this dell. what is the part#?
Update (05/22/2016)
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
doesn't look like a full length opening in back.
의
is that a regular PCI slot? not a pci e.
의
댓글 달기
답변 3개
가장 유용한 답변
Dell ATI Radeon X300 SE H3823 128 MB DDR SDRAM PCI-E Graphics Video Card DMS-59
This is the video card is the one we use in our Dell GX 280 student computers.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Jim, I looked at the link you sent and those seem to be a full height slot. My DELL has a low height 2.75 inch opening.
의
http://www.amazon.com/ATI-HM300L-C3-Hype...
Sorry about that. This one is a low profile card and should work for the gx280 desktop.
의
댓글 달기
If it has dedicated graphics than most likely any video card that can fit in it with the right slot (most likely pcie x16 or pci) and if the power supply can power it...
I can tell you exactly what you need if you can send a Picture of the back and inside without the graphics card...
이 답변이 도움이 되었나요?
점수 0
댓글 7개:
Also if it has integrated that went bad then you will need to get a graphics card/new CPU depending...
의
here are some pics
의
ETHREAL1-- Why would you need to replace the CPU?
의
OK so you need a video card that is PCIE X16 single slot so something like this...
http://www.newegg.com/Product/Product.as...
But it depends on what you are going to use it for...
If you need some more help let me know
의
And in reply to "LS Computer Systems" he may not have to but if the integrated graphics died there could be more things wrong with the CPU on the same chip...
Something that is very probable if after he gets a GPU it doesn't boot...
의
댓글 2개 더보기
댓글 달기
You could get away with a Radeon 5450 I think if you cannot find the X300.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
randymack123 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 14
전체 시간: 1,157
