주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
얇고 가벼우며 강력한 성능을 자랑하는 것은 물론, 놀라운 사운드와 Wi-Fi 기능을 갖춰 이동이 잦은 사용자에게 꼭 필요한 기기입니다.
HDMI port quit working
I have had this notebook for a year, and have connected as many as two external monitors (using the thunderbolt port and HDMI port) with no problem. I just moved, and now when I set up, with an external monitor using the HDMI port, the notebook does not see it. The control panel only shows the built-in display available. I have checked the cable and the monitor and they are fine. Is it possible my HDMI port failed?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 3개
가장 유용한 답변
Hold on here a second... Found something that worked for me. Right here, from this site;
Windows 10 HDMI Connection Intel Graphics Issue
Disable and enable the driver, configure project once again. Odd, but I'm happy with this, until HDMI stops working again ;)
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
hi have you solved your problem with the asus ux510ux? I am having black screen with an external monitor
의
On the second monitor, open the windows notification thing at bottom, and there should be various display options.
의
댓글 달기
Hi,
I am currently fighting with ASUS UX510UX and HDMI issues. Before this, I had UX305, which I gave up believing that its HDMI port had broken suddenly down. I was mistaken.
With UX510UX I soon encoutered the same situation, HDMI ceased to function. This happened with the 1607 update and I rolled it back and this restored HDMI functionality. All was fine fore few weeks and then Win10 updated driver files (you cannot prevent this, unfortunately) and I lost the functionality again.
I was in touch with tech support and they provided me with a installer that overwrote all relevant files and HDMI was restored once again... until today when some kind of a driver update once again took place (you hear that "device connected" sound and screen flickers, then you know that you just had unwated driver update). This time the provided package could not restore HDMI functionality and I am currently trying out reinstalling.
Win10 built-in "Reset" is no good, even with "remove all files" option. Nothing changed and all the bloatware just came back. Now I am performing a factory reinstall with tech support's help.
None of this is likely to help you, but you're not alone and it's unlikely that your hardware is at fault.
You might also be interested that these HDMI issues are occuring with other brands too. From the looks of it, this may be related to all motherboards that have certain Intel chipsets and/or GPU (I believe these are all built into the mobile chip these days). Why this may be of interest is that in Microsoft site some users have reported a success overcoming this issue by locating and buying a "better" HDMI cable. I lack the expertice to speculate if the cables have (or lack) features to cause these kinds of issues (let's imagine, if the driver suddenly relies on some signal/data/other from the monitor before activating...), but this is something I will look into, as I move along with all these attempts to restore HDMI to my laptop.
If you discover something, please let others know - and if you have any influence towards the brand or MS, please try to make them care about this issue :)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hello,
It's possible that it is your HDMI port failed, but before go on ASUS web site and download the latest video driver for your Zenbook UX303L.
Download it
Install it (without connection to your external display)
Restart your laptop (with your external display connected to your laptop)
The problem can be the driver.
Regards
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mike Ricks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 33
전체 시간: 19,896
