주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이제는 단종된 Minolta 제품군의 필름 및 디지털 카메라 수리 안내서입니다.
Battery casing of Minolta Camera
The cap of the battery casing of my MinoltaDiMageZ1 camera cannot lock close - the pin that locks the cap broke off. I am keeping it closed with masking tape, but that doesn't hold long and I have to keep changing it.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Can you tell us the exact model of the camera?
의
댓글 달기
답변 2개
선택된 해법
Broken battery door latches appear to be a common problem on the Dimage Z1. I did a search for spare parts on this model and the battery door came out at the top of the list. However, the spare part is no longer available.
The best solution might be to use velcro to make a locking strap, as follows:
  • Obtain some 3/4" wide velcro tape. Not the self-adhesive type as this is not practical in this application.
  • Cut a 4" piece of loop tape (the "fuzzy" part of the velcro) and fold 1" at one end over itself with the fuzzy side out. Glue the end onto itself with a strong flexible glue such as contact cement.
  • Cut a 1/2" piece of hook tape, and glue it to the center of the battery cover.
  • Glue the loop piece to the side of the camera body, fuzzy side out, in such a way that the folded-over end sticks out over the battery cover, and can be folded over to grab the hook tape on the cover.
The result might not be a work of art, but it's more practical than masking tape.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I solved same by getting a 4 aa battery case and connecting to the ac power port.
Found this by trying to locate the specs for the port, seems like "tech specs" have deteriorated since paper went away. Am not sure of plug specs but found one in my wall wart collection.
의
댓글 달기
Parts available on ebay but adapter kit needs to ship from china. I got lucky and found the right plug in my wall wart collection.
https://www.ebay.com/itm/For-6V-4-AA-Bat...
https://www.ebay.com/itm/8-Tips-Universa...?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Do a 3d scan of the door and 3d print new ones out
의
댓글 달기
답변을 추가하세요
Sara Sharlow 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 37
전체 시간: 1,971
