주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
듀얼 마이크와 802.11ac 무선 연결을 탑재한 대형 MacBook Air 노트북입니다.
MacBook Air SMC problem
Hi all,
I have a problem with my macbook air 6,2.
The first issue was the computer did't turned on.
The SMC reset and regular things did't helped.
I took down the bottom case, and plugged out the battery cable. After this when I plugged in the charger, the computer is turned on immediately.
I took back the case, and restarted the computer, the computer was dead as before.
I ran a hardware diagnostic test and got the PPT001 (battery), PFM001 (SMC) and NDC001 (webcam - this one is weird because I can use the camera).
So right now I can turn on the computer without the bottom case, but the fans are running high etc.
The power adapter led is not lighting, and when I push the shift + ctrl + alt the computer is turned off immediately.
Anyone have an idea what can I do with this SMC issue?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
Hi,
I have exactly same issue with my Macbook Air 13" 2014.
How do you repair it?
의 공유
First issue was fixed without any intervention. I just waited few days..
The secound issue was the SSD, so I just replaced it. Maybe the first issue was an SSD issue as well.
의 공유
@wntsmk I have the exactly same issue with macbook pro mid 2012 ....what I have to do please help me
의 공유
댓글 달기
답변 3개
선택된 해법
Yeah it was my first idea. Few days later the computer turned on and worked fine.
But another few days later started to do a weird things, for example restart without any reason. After one of the restart the OS never started again. I checked the SSD with the install system, and haven't seen it, so I ordered a new SSD, and now everything is fine.
Maybe the first issue reason also was the SSD.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
ok i'm happy your problem is solved.
의 공유
댓글 달기
Guessing right now but, what if you replace the EFI BIOS chip?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello, I can recommend a company in Turkey that can repair this malfunction. Prices are reasonable and experts in the repair of the MacBook https://kaptanbilgisayar.com.tr/atasehir...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
wntsmk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 7,502
