주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TV HDMI 포트에 직접 연결하는 소형 미디어 스트리밍 기기입니다. 2014년 11월 Amazon에서 처음 출시되었습니다. 최신 버전에는 음성 인식 리모콘이 포함되어 있습니다.
How to open FireTV Stick remote
Any creative ideas for how to open the fireTV Stick remote when you first get it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 달기
답변 5개
가장 유용한 답변
The two best options, as it turns out, are 1. Just pull really hard, or 2. Use a screwdriver to pry it open.
Here is a YouTube link that shows how:
https://www.youtube.com/watch?v=F__fFr7n...
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I went down the screwdriver route. Many thanks for the suggestion.
의
댓글 달기
Simple once you know how. Hold BOTH ends of the remote, squeeze both ends gently and slide forwards
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I agree. Sometimes, the new plastic pieces have micro texture edges resulting from the fresh cutting from the making of the pieces that give it a bit of a grip against each piece to where you will need to use something that allows you grip it better, like rubber gloves, or even a rubber band. I too had serious trouble opening it the very first time. I used latex gloves to open mine once, after that I could open it easily with bare hands. If you put a rubber band on your thumb and push it open that way, my bet is that it will open for you.
의
Latex gloves worked - still have to push hard - Thanks
의
댓글 달기
The person who designed this remote should be fired. Seriously.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Couldn't agree more. It's totally ridiculous for such a sophisticated device to be missing a little notch to open it easily.
의
댓글 달기
I received the Amazon fire stick remote today, and took me quite a while to figure out the best way. Every time I press on the indent and move it up it opened a teeny weeny bit, and not any more. So finally, I pried it open a little and put in the batteries
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Phew! Ridiculous! Took suggestion from YouTube & used rubber jar opener to gain traction while pushing down-still very tough!
의
댓글 달기
Watched a video on YouTube with a very simple trick that works great. Turn the remote over so the little arrow is pointing up. Grip it firmly in your hand and hit the end firmly on a hard surface. If you do it right, the back cover pops right off. I got it off on the first try.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Show a diagram with instructions!
의
댓글 달기
답변을 추가하세요
Mitchel Szazynski 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 40
지난 30일: 123
전체 시간: 38,868
