주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TDK Life on Record Trek 360은 TDK에서 제조한 휴대용 무선 스피커입니다. 이 스피커는 보조(AUX) 포트를 갖추고 있으며 무선 및 블루투스 연결을 지원할 뿐만 아니라 360° 사운드를 제공합니다.
Charging port not working.
My TDK speaker will no longer charge. The red indicator light doesn't come on. I can sometimes wiggle the wire where it plugs into the back and it will light up, but I have to hold it in that one spot for it to charge. It has now got to the point where that doesn't even work any more. Can this be fixed and if so, where can I order parts for it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
TDK sucks, no support or warranty. Nothing. Just discontinued the product.
I actually ended up fixing it myself.
It's not the battery. The problem is that when you wiggle the charging socket, over time it gets de-soldered from the circuit board. So you need to solder it back.
Open the unit per instructions on TDK Life on Record Trek 360
Then you have to break the black seal to get access to a small circuit board where the charging socket is.
You will see the issue once you open it, it's obvious. Solder it back to the board and assemble back.
Removing the bottom speaker will help too and make it more convenient to fix.
의
Hey there, I’ve been having the same problem and am in the process of taking the speaker apart to access to charging port. I’ve removed the clear seal around the box concealing the small circuit board, however it still won’t come off. I’m worried about breaking something if I try and force it. Any tips?
의
댓글 달기
답변 1개
선택된 해법
Usually in a situation like this the port has separated from the circuit board and needs to be re-soldered. It could also be the port itself has broken . I would start by removing the case around the port and inspecting the charge port to see if the solder is separated at all from the board. If it has you can repair it with a hot air station and some tweezers to reseat the existing solder joint. Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
terrisathome 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 2,765
