주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
음극선관(CRT) 기술을 사용합니다. 구형 모니터와 텔레비전은 수년간 이 디스플레이 방식을 사용해 왔습니다. 작업 시 매우 위험할 수 있으나, 간단한 수리는 가능합니다.
Black lines on screen
There are black lines on the top and bottom of the screen. There are not any potentiometers on the back so I can't change thr picture manually. What can I do to make it look like 4:3 again. This is a crt tv by the way. Thank you in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
eraywhite what make and model is this TV? What have you tried? Post some images of what you see with your question. For that, use this guide 기존 질문에 이미지 추가하기 It will allow us to see what you see.
댓글 달기
답변 1개
You don't specify what make or model. On the older crts the gross adjustments are inside the monitor the outside controls are for fine tuning.
DANGER! DANGER!
To adjust the gross setting it involves removing the back cover and working near the high voltage flyback with the power on.
ONLY USE PLASTIC OR INSULATED TOOLS
(I ALSO WEAR RUBBER GLOVES)
CRTs can KILL....
There should be three plastic potentiometers with slots cut into them for a small flatblade.
On really old CRTs they also used small magnets attached to the sides of the picture tube as well.
Adjust the monitor slowly. If possible have someone else watch the picture while you adjust so you can insure not touching a live board.
You life is not worth an inch of black screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
eraywhite 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 1,406
