주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D600 24.3 MP CMOS FX 포맷 디지털 일안 반사식(DSLR) 카메라
How do I open this ZIF? Connector?
이미지
이미지
Hi,
This is the underside of top of my D600 that I dropped. To mend the top display I had to remove this board and do some soldering.
I pulled out the ribbon that goes into the white connector at the bottom of the board as you view it - see attached photos.
I pushed back the ribbon, although it did no go completely in. After re-assembling the camera I found the wheel under the forefinger inperative.
How do I unlock this, I have so far not tried too hard as I must not break it!
hope someone can help,
John
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
every zif connectors have a plastic lock on it, just unlock with a small flat screw driver and pull out the ribbon cable carefully, when reconnecting extreme care should be taken.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The black part of the connector is the part that flips up to release the ribbon cable. Still be gentle with it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
John Bishop 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 974
