주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.6 또는 1.8 GHz 듀얼 코어 프로세서, 2 GB 또는 4 GB SDRAM, 64 GB 또는 128 GB SSD
Bottom Left Corner of Trackpad Sunken
Through some sort of blunt trauma in my bag, the bottom left corner of the trackpad (where left click would be on normal trackpad) has sunken into the body of the Macbook.
Although the click still works, it is a bit temperamental, and tap to click still works, although it has made click and drag difficult.
I am most worried about it eventually breaking from being in the wrong place in the body.
Is there any way of fixing this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
선택된 해법
Here's the guide to working on your trackpad: MacBook Air 11" Mid 2011 트랙 패드 교체
It has most likely been pushed in a little and the edge is trapped under the lip. Use a #000 Phillips driver.
This is a very easy fix most of the time. Taking it to the Apple store is like going to the doctor for a hang nail.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
You have to take out the battery and move the trackpad up. I would most likely have the apple store do it so you don't strip the screws on it. It fairly simple to do and would fix the problem fast. Its a issue with the metal plates that hold it in shifting from the blunt force.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Does this work for surface go keyboard cover? Sometimes when I click, it gets sunken in and it doesn’t stop clicking and when I move the mouse it registers as a click and drag and I have to bend upwards my keyboard for it to stop or put my nail around the trackpad and push it up. How can I fix it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ed Manthorpe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 68
전체 시간: 29,052
