주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
경미한 스타일 변경과 새로운 엔진 사이즈가 적용된 2세대 Ford Ranger입니다.
replace lower intake manifold
how do i remove lower intake manifold
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
What engine do you have?
댓글 달기
답변 1개
선택된 해법
First remove the upper air chamber then remove the fuel rails and injectors make sure you have drained the engine coolant completely before unbolting the intake then once the coolant is out remove the bolts that secure the intake and pry from a corner to break the seal of the old gasket. If you go to youtube you can usually find all sorts of videos on this. As Im not sure on the engine or year I cant show a specific video
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
For some reason I have a that goes right through the lower intake manifold, how do I remove the valve to take off manifold?
@mr_dawsey it would be good to have your exact engine and year, it seems that there should be videos on YouTube according to the previous posts, good luck.
댓글 달기
답변을 추가하세요
fernandorudolfo189 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 24
전체 시간: 2,273
