주요 콘텐츠로 건너뛰기
Retina MacBook 2015의 업데이트 버전. 모델 A1534, EMC 2991.
Possible to unplug camera and microphone(s)?
Is it possible to unplug the camera and microphone(s) on the 12" Retina Macbook?
I've used past iFixit guides to do this on older Apple devices. For example, in these Macbook Pro teardowns you can see where to disconnect the iSight camera and microphone.
Does anyone know if this is possible on 12" Retina Macbooks?
MacBook Pro 13" Retina Display Early 2015 Display Assembly 이미지
안내서
MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement
난이도:
조정
30 minutes - 1 hour
MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly 이미지
안내서
MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly Replacement
난이도:
조정
40 minutes - 1 hour
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Thanks for the advice, Dan & Larry. I realize that tape/glue/etc is commonly used to "disable" these, but I'd prefer a hardware solution if one is possible -- and it has been possible with other Apple notebooks.
Checking the teardowns for last year's model, it looks like the microphones are unpluggable (and that this doesn't disable the audio jack itself, since that's a separate step). But I haven't been able to find anything similar for the iSight camera unfortunately.
댓글 달기
답변 3개
가장 유용한 답변
Your only hope here is tape to cover the iSight camera lens & a cut off head phone plug to kill the internal microphone!
This series uses a highly intergraded architecture to such a point there is no means to disconnect internally the camera or microphone physically.
With that said why are you worried? Unless someone has direct access to your system to RAT it, there is no means to spy on you without you knowing.
Besides you can always turn the system off or put it to sleep mode ;-}
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Are you trying to simply disable them or replace them? If you just want to disable them, use black tape for the camera and perhaps unsolder the microphone if it's not on a connector somewhere. Or just use glue or tape.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had no problem disconnecting the cables on my 11" MacBook.
Furthermore, I have done the same on two Dell models.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Very different animal here ;-}
This series of MacBook is very different than your older MacBook (retina Vs non-retina).
댓글 달기
답변을 추가하세요
wizfish mcfrabblegabben 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,524
