주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2004년에 출시된 HP Compaq 비즈니스 노트북입니다. 이 모델은 이전에 출시된 Compaq 모델들과 많은 유사점을 공유합니다. 모든 노트북은 Pentium M 프로세서(32비트 전용)를 사용하지만, 특정 구성에 따라 속도는 다릅니다.
replacing memory card defaults
I have an old HP compaqnc6000 is it the same teardown as the one listed and if I just replace the memory card will I be able to reset it for personnel use and how does the DVD work
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I had the use of one of these for business a few years ago, and though a little old and heavy, I liked it. It should still have some life in it for basic email and web browsing.
However, it's not very clear from your description what the problem is and what is preventing you from resetting it. If there's a BIOS password preventing it from booting up at all (no Windows logo appears) then resetting it may mean partial disassembly and doing something inside. The memory card under a cover on the bottom is the RAM and replacing that won't have any effect.
Your best bet with a machine of this age would be to reload it with Linux Mint since Windows XP is long out of support and it may not be capable of running a current version. How to do that is beyond the scope of a brief answer but for a start you could look at rstrt.org/wiki and under Computer Hardware and Computer Software, check out the articles entitled Linux Migration and SSD Migration.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Charles S 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 21
전체 시간: 461
