주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 출시된 Samsung ATIV Smart PC 500T는 1366x768 픽셀 LCD, 64GB 저장 용량, 최대 1.8 GHz로 구동 가능한 프로세서를 탑재한 11.6형 Windows 기반 태블릿 컴퓨터입니다.
Where is the hard drive
what does a sumsung ativ 500 t hard drive look like and where is it located?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Light browsing for this i found no replacement harddrive. And looking at the backplate disassembly and battery replacement here on iFixit, I can't for the life of me imagine where you'd fit a normal ssd drive in there, making me believe it has an eMMC drive. As in on a chip, like on a phone.
Found some usefull information about eMMC on How To Geek.
Not an expert here and would happily be proven wrong.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
Thanks David, after reading what you said and had another look around i found the emmc chip under the silver plate. I think i am going to have to send it away to get the data off as my screen smashed , discoloured and i can not log in.
의
Did that work for you @Nicky ? I also need my data !
Is there any methods and ways I can learn how to extract it?
의
how do i remove the silver plate?
의
@urban_potat does not look like anybody is going to see your comment on this 6 year old question. Same device? Same question? How to remove the shield under which the eMMC drive is located?
의
댓글 달기
I had this problem owing to a windows update, to re-start I held down the volume switch and at the same time held down the on button this gives a menu with several options. I chose to use the recovery option and the tablet rebooted as normal.
Hope this helps
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
no system restore or factory reset
의
댓글 달기
Hey @badgerfromhell - You could use a mini-HDMI cable to connect to a display with HDMI, because the ATIV Smart PC does have a mini-HDMI display port.
Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
nicky 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 34
전체 시간: 6,541
