주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
미국에서 티뷰론은 1997년에 처음 출시되었으며, 기본 모델은 엘란트라의 1.8L 130마력 엔진을 사용했고 고급형인 FX 모델은 2.0L 4기통 엔진을 탑재했습니다.
engin light is comming on
why is my car hesitating wile driving
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
More information about how the car is running would be good and as @mayer suggested get the engine code read . this can help a lot when trying to diagnose the problem
댓글 달기
답변 2개
선택된 해법
First thing I would do is to take it to an AutoZone and get a free computer read out.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hi, if your engine light its blinking on the dash while you are cruising and the car it's hesitating, it means that you have 1 or more misfiring cylinders. That may be for several reasons: check your sparks, sparks plugs or ignition coil.
Then if is all good check you fuel pump and filter, and be sure to have the correct pressure on the injectors and all working.
In any case it's very useful an OBD Scanner, because it could tell you exactly which cylinder is failing so you can focus in that one.
That's the easy and less expensive thing. if it's all good, it may be a head gasket or worst, timing belt or an endless list of possibilities.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kohli5162 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 24
전체 시간: 845
