주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Pro 2는 2013년에 출시된 태블릿과 노트북의 하이브리드 기기입니다. Surface Pro 2는 Microsoft의 Surface Pro 후속 모델이며, Windows 8.1에서 Windows 10까지 지원합니다.
LCD ribbon cable dmg
Hi,
Today got new LCD display + touch after I connect everything nothing dosent show on screen but surface sound as working. Also when setup old broken lcd nothing happent. So I think lcd ribbon cable is dmg , here is image of cable https://postimg.org/image/xemi57umf/ i, down right corner look as dmg missing small part of connector. How can I fix? Because new cable cost 50$ , so if can will like to save that money
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
Hi,
I solved problem by replacing ribbon cable. You can find on alibaba for arround 5$.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have the same problem. I brought and connected up a brand new LCD screen for my Microsoft Surface Pro 2 but although all the sounds and vibrations are working perfectly on the device I can't seen to get the display to show any visuals. Has any body had and solved this issue and if it is a faulty display ribbon, does anyone know where I can buy a new one from for a reasonable price.
Thank you.
Kay
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Cheers Flegy.
I've ordered a new ribbon from Alibaba but couldn't find the same sort of bargain as you. I paid $18.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Ye when I was order before few years cable was cost 5$ now price is from 10-20$
http://s.aliexpress.com/6zaMZzuu
의 공유
댓글 달기
Same issue. You may find that the screen works but it's the back lights that aren't functioning. You can test this by angling a flashlight to the screen while the unit is on. You should be able to see the graphics but very dark. Another way is to connect the mini display port to an external monitor. This worked for me.
Back to the issue. I replaced two screens and one costly cable but none of that helped. I have the option of connecting to a docking station. My Surface Pro 2 can no longer be used as a tablet.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
So sad to hear you didn’t solved screen problem. I replaced on my surface LCD + ribon and it work fine.
의 공유
댓글 달기
답변을 추가하세요
flegy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 47
전체 시간: 2,269
