주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
발표 - 2014년 11월 Samsung Galaxy Core Prime (G360, G361)은 1.3GHz quad-core 프로세서로 작동하며 1GB RAM을 제공합니다. 휴대폰은 8GB 내부 저장 용량을 제공하며 microSD 카드를 사용하여 최대 64GB까지 확장할 수 있습니다.
fix crack at home
how can i fix cracks manually, at home, without buying or paying for anything?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
You will at least have to buy a glass for the screen and replace that, but a glass is like $8 with free shipping. Be warned though, glass only is very difficult, and you will more likely than not ruin the LCD.
glass
http://www.ebay.com/itm/like/30199621611...
some resources to look at on glass repairs(you should look up more, this is just a starting point)
http://www.youtube.com/watch?v=z9drzO9hO...
https://www.youtube.com/watch?v=SJ05sPZD...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I have to concur with Ethan on this one on having to at least by replacement glass. Although I have done a few of these core Primes with no damage to the lce as they are not laminated together.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Would just changing a cracked glass on a core prime be easy? it's not badly cracked and the frame under it has no damage at all. its a core prime g360t1.
의
Yes it only has adhesive on the edges of the device you have to worry about around the home button and in the upper right hand corner so that it doesn't cut cables.
의
댓글 달기
답변을 추가하세요
tlomov 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 1,353
