주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
독특한 슬라이드 아웃 배터리 및 다중 하드웨어 확장 옵션을 지원하는 분리 가능한 I/O 모듈을 갖춘 LG의 주력 스마트폰. 2016년 4월 출시.
half the screen has dark lines
Half of my screen has dark lines going through the left side of the screen and it will not respond to my touch. The battery is also overheating each time I put it to charge. What do I need to do to fix both of these issues?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개:
Is the screen cracked? Waterdamage? Repaired before?
의
Hey Cristal, I would defiantly like a little more details, how did it get like this? Did it drop or has the device been exposed to water?
의
댓글 달기
답변 4개
The screen is not cracked and has never been repaired before. About one month ago water did get to it but it did nothing to my phone. My now ex boyfriend had slammed my phone on the ground 2 to 3 times.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Whoever had slammed your phone has caused the problem. Get a new screen.
Update (02/02/2017)
Is it cracked? How long have you been using it? If you have been using it for a long time, try getting a new battery. If it's cracked then you should get a new screen. If it's not cracked then open it and if there isnt a wire connecting to the screen, look at a teardown to see what goes where.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a similar issue and saw that with a dif. model several people had the same problem as well. The prevailing sentiment is that it is a defective battery and can be fixed by replacing said battery.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I replaced the battery, but the screen still has black lines and won’t repond to touch.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
cristal rosales 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 14
전체 시간: 2,453
