주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
How do I fix my liquid damaged Xbox One?
Two weeks ago, I spilled 2/3 of a cup of washing up liquid into the the top fan of my Xbox One (don't ask how). Since than I have contacted Xbox Support and have read multiple forum threads saying you should let nature take its course (basically wait and see).
Things I have tried:
  • The rice thing
  • Putting it under a fan for 24 hours
  • Tilting it to the left for 18 hours
Although many recommend to teardown your console and clean it from the inside, I personally do not wish to take apart anything like this, and yes I can go to Repair Shops to fix it, but you see I am trying my absolute best not to spend any money because of Project Scorpio (ofcourse).
Please any advice or tips on how to fix my Xbox One will be most indeed helpful. If you wish to recommend me Repair Shops; make sure their in Birmingham, United Kingdom.
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 23
댓글 41개
What is the "Rice Thing"? I'm just wandering
Look It Up On YT
Thank you, i just spilled a lot of water on my xbox 1 S and was VERY scared and thought all my files would be gone again. I turned my xbox on the side and put a hair dryer on a good warmth.
well try getting a new plug, the graphics will be crap but if you get a new one the fumes of the liquid will not disturb the plug. also put upside down for around 1 hour and then get a hair dryer and dry it. if its dried then leave for a few mins to calm down till its cold like room temperature (what ever).
It should work....
my ignorant girlfriends brother spilt half a cup of coffee on my Xbox 1, what do I do!!!!!
댓글 36개 더보기
댓글 달기
답변 18개
선택된 답변
@zohaibkeyani first off "The rice thing" absolutely bogus. Does not do anything other than give you a false sense of doing something. Forget the rice altogether. You will have to disassemble your xbox and clean it properly. Use these guides to work on it. Then clean your parts with high grade (90%+) isopropyl alcohol. That means all parts. Once done reassemble and evaluate for any failures. For further help with this I'd suggest you contact the console guru on here. Yes we all like to spend as little money as possible, but if you do not fix this now it will cost you much more later on.
해당 답변은 도움이 되었습니까?
점수 13
댓글 20개:
Hey what about 70% alcohol? Will that work?
@meagercode nope. 70% still has 30% water. It will take much longer to evaporate and will evaporate a disproportionately large percentage of its alcohol, leaving the remainder with less and eventually leaving only water behind.
I'm not sure how much liquid you spilled but you'll likely want to do as @oldturkey03 says and disassemble it and clean it and remove any and all corrosion. Then let it dry 100% and put it back together and try it.
What if it is distilled water.
Does not evaporate quickly enough.
댓글 15개 더보기
댓글 달기
My son spilled a good amount of water onto his. It would turn on then turn right back off at first. I unplugged it shook it out then used the blow dryer on it for about 15 minutes rotating between warm and cool air. Hope this helps, the blow dryer suggestion saved his and I’m sure it will help
yours too, if it doesn’t let it dry out for a couple more days and try again before buying a new one.
해당 답변은 도움이 되었습니까?
점수 11
댓글 2개:
so do all want you sed
thank you so much i was able to save my brother in laws xbox because it fell outside in the snow now it works perfectly fine you also have to make sure the blow dryer is on high
댓글 달기
I shut it off blowed in it put it in rice left in under a fan tilted it but it will turn on and then turn off
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Then it should work with no problems.
댓글 달기
I took apart my Xbox one and wiped it down bc it was very dusty. The inside did not look like it had any type of water damage, but ever since my son spilled water on it it hasn’t worked. Since I have taken it apart, and done all that what would be something else I could try? If anything.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
All u guys need to answer on question
Was it on when u spilled or have u turned it on since u spilled if so good luck if no fo the blow-dryer thing it works I'm fact Everytime it rains outside I have to pull the cover of my Xbox one and blow dry it on hot for 2 minutes then it works ….done this maybe 20+ times so far so good…..
I'm sure this is in the PCB or a part that Microsoft put on to do this very thing so u would take it to get fixed and spend money….I wish someone would reverse engineer it and figure out a permanent fix
Steyr223
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
@steyr223 what if your sensor doesnt glow will the blow dryer still work
I spilled milkshake on my xbox one since it doesn't want to work again what must I do
As an update ifixit sent me a email that said my answer helped 1.7k people
Cool so I clicked on it and here I am
Any time it gets moist or wet outside I would need to do the blow-dryer thing
Don't use it on high and don't sit in one spot for any amount of time due to risk of melting $@$*
With the laptop I do it on medium for about 3 min
I hold the on button for 40 seconds then try to power on it has to sit with power supply plugged in for about 20 mln and it just comes on by itself
And I don't take it apart just do it through the venting
It is a rog zephyrus
댓글 달기
What do I have to do if I spilled lemonade in my Xbox one s
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Shut it off, unplug it, and let it dry. Assuming that the liquid didn't get inside the Xbox, dry it off for a few minutes then you can plug it back in. If it gets in the Xbox, clean the system up with Isopropyl Alcohol to avoid corrosion.
댓글 달기
I got some water in the fan. I tried drying the top off with a cloth but when I plugged it back up it didn’t work.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
My son poured coffee all over mine anyand it went inside so can anyone help me
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
That just happened to mine about an hour ago. Maybe more or less. I wasn't here when it happened. My mother and girlfriend we're, though. They immediately turned it upside down. I didn't think to unplug it. Because, I was upset at the time. I just hope it comes back on and nothing happened to it.
My mom was the one who accidentally spilt her coffee, and idk how much. But, she started to cry when I came in. They didn't know what was going to be my reaction, but, they obviously thought it was going to be bad. To their surprise, I took it well.
Mom's offered to buy a new one. Gf did too. But, like I said, I hope it comes back on and no permitting damage to it.
What happened to yours?
댓글 달기
i jizzed in mine (dont ask how). Since then, I have contacted Xbox Support and have read multiple forum threads saying you should let nature take its course (basically wait and see).
  • The rice thing
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
it broke nvm
lol
Wdym don’t ask how? For real how did you buss a nut on your xbox
wtf did i just read lmao
nah cause how did you bust a nut on your xbox WHAT WERE YOU DOING BRUH
댓글 달기
My cat knocked over my beer on my Xbox one it was standing up and got all the top of it wet I’m so fked
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
call 18004myxbox the peoe send you a shippping label thats paid for then zend it to them and if they cant fix it they send you the same xbox refurnished of course but you avoid having to deal with it
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Brandon Nutting watch your language!
댓글 달기
My little brother spilled water in the top of my xbox i shook some of the water out then tilt it over and let it drain it’s been in the same spot for 3days and i took it to try and see if it would turn on again and it started making this chirping sound from the back where the power plug is and i dont know what that means…or what to do about it
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Me neither same
댓글 달기
Since I already answered this question I thought all these new questions were just getting posted to my email for whatever reason
I'm looking for the answer I don't see it so here's the answer take your Xbox apart take a hairdryer don't put it on extremely hot you'll burn something up, blow dry it for 5 minutes put it back together it'll work
Since I live in my vehicle in California ,I have to do this maybe twice a month due to moisture build up in the rainy season
As far as taking your Xbox part just take the outside cover off so you can see the board that's all you have to do
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello,
I had the same problem , and I thought it was the End of my Xbox, but then, I tried to clean it, and I put it under the Sun rays and everything worked ok! I am just telling you don’t lose feight everything might be Ok.
Kind Regards
Alex
Editeur chez ThemesChamp
Thème de wordpress
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
My son spoil water in the fan of his xbox and won't turn on but there power going thou it' as controlled come on what can I do
댓글 달기
Hello,
Kind Regards
Your Website
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
So, my son broke his xbox by spilling milk on the top. I did the tilt thing or wiped it down when it happened. It has now been 5 months later and it is still sitting here. Is it a lost or is it possible to get it fixed?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My two-year-old sprayed bleach spray into our Xbox one not very much but it was still wet to the touch what should I do
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you Need to unplug it instantly, lay it facing up and point a fan towards it and leave it for a couple hours. I've done this twice on my Xbox series s and it fixed both times. hope it helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Zohaib Keyz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 25
7일 전: 170
30일 전: 874
전체 시간: 238,191
