주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 7인치 RCA 태블릿(모델 번호 RCT6773W22)의 수리 및 문제해결 안내서입니다.
Green Border around Screen
My RCA tablet has a green dash border around the edge of my screen. I have tried turning it off and a reset but still the border and the device will not work. When touched the border will move to a box or rectangle around the area touched. Pls help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 4개
can you post pictures of what exactly is happening? this is a strange issue, never heard of it before. If you are getting a red border, resetting the settings in developer options will fix that.
의 공유
My son has this issue . What soes it mean??? Help
의 공유
post pictures of the issue
의 공유
How do i get rid of that green border around my fire tablet i can't get in to anything
의 공유
댓글 달기
답변 3개
가장 유용한 답변
I had this problem too, you have to hold the icon that you need to use until the green box pops up, and then double tap, once you have it unlocked, do the same thing (hold down and double tap) to settings, and turn off talk back (you might need to search it once your in settings, like I did) and then your tablet should be fine after that.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I am having trouble now I am stuck in my camera
의 공유
댓글 달기
How do i get this green box from my RCA tablet
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I would check if you accidentally turned on show screen changes in a developer mode. if not it could be a small internal crack in the lcd. UPDATE: re reading it you have an assistive touch on. look in your settings and accessibility settings and make sure everything is turned off
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Liam Boland 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 4,869
