주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 10월 22일 발표, 11월 12일 출시되었습니다. 레티나 디스플레이를 탑재한 iPad mini라고도 불리는 iPad mini 2는 iPad Air와 동일한 픽셀을 더 작은 7.9형 폼 팩터에 담았습니다.
iPad mini 2 display flickering
My iPad mini2 has display problem, I didn't drop it, it just happened suddenly.
Does anyone have the same problem? Anyway that I can fix it by myself?
Thank you.
https://youtu.be/r6sfKtNMSKs
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
선택된 해법
First, thank you so much for the video. It helps a ton.
I'm kinda torn on this one. It looks like an extreme case of ghost touching, which would mean a new digitizer would fix it. But I've never seen one on turbo like that. If it were me, I'd start by trying to restore it in iTunes. Its a 5 minute, free fix. If that works, great. Otherwise its almost certainly a bad digi/digi IC that is causing it to go nuts.
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
I did try reset factory setting, but remains the same.
And I have been thinking of whether I should replace either the digitizer or screen, or both.
Normally that kind of thing is because of the IC on the digitizer cable. Digis are pretty cheap for Minis, so try that first. I highly recommend getting one from a reputable supplier like ifixit, mobile defenders or group vertical.
As far as the people saying to check the LCD cable, that doesn't make much sense. The icons jumping is the key symptom to focus on. That and I have no idea how an LCD cable would magically need reconnecting.
Try a new digi and report back
Thank you so much for your advice. Will report back after the fix.
any update ?
댓글 달기
You can check your flex cable connector. But most likely you would need a new screen
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
For the cable connector, how can I tell if it needs to be replaced? Seems that my iPad definitely needs a new LCD screen, right?
댓글 달기
mine is just vertical lines in the half of the screen if some of you has this issue i tried a few thing temporaril
y and right now im still trying to find solutions , this happened when my Ipad Mini was 7% batt. left and i forgot that it wasnt auto locked so it was still open and when i came back from finding my charger it was 2% and started to do the vertical lines but it was gone after the battery drained at 0% and it came back when i was using it for a lot of hours while charging,if anyone of you has this problem then ill try my best to update you all if i found a fix for it
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Lines sound like a loose connection, I also had to replace an LCD with no obvious physical damage when the loose connection wasn't the problem.
댓글 달기
iPad screen displays flickering? This post (https://www.joyoshare.com/iphone-repair/... ) can help a lot.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
bBing 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 22,260
