주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 6월 출시, 유럽 모델 번호 A3003 및 중국과 북미 모델 번호 A3000(https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/ 참고)으로 식별됨
How to answer call?
I am unable to answer incoming calls on my Oneplus 3. I get a phone icon on my screen but nothing happens when I touch it. I can't use the power button or the home button to answer calls and swiping does nothing.
Is this an Android bug? Is there just some way to answer the Oneplus 3 that I don't know about?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 2개
I cant find keys but can find buttons but there is no option to answer calls?
의 공유
I want to answer my call with the home button on my OnePlus 3. But there is no answer call option in the buttons menu.
Please help
의 공유
댓글 달기
답변 4개
가장 유용한 답변
I had the same problem on my 3T and have found the answer.
1. Press the Phone Icon
2. Press the 3 vertical dots in top right hand corner
3. Press settings
4. Press Call settings
5. Go down to "Receive incoming calls" and move the slider button to ON!
The manual doesn't seem to mention this feature but that cures the problem.
이 답변이 도움이 되었나요?
점수 7
댓글 4개:
It works. Thank you.
의 공유
fantastic this works many thanks
의 공유
Thanks Tony, that works. I wonder who thought it a good idea for a phone not to receive incoming calls by default?
의 공유
Brill, thanks
의 공유
댓글 달기
Hi Ness,
I'm not sure what a long term solution for that is, but you could try these steps for a temporary fix:
Go to SETTINGS then -> KEYS -> then under HOME KEY -> select to ANSWER CALL
Ideally in this scenario you can now press your home key to answer an incoming call.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You do not need to play with the settings actually. Answering the phone is slightly different on the OnePlus.
You put your finger on the middle "blue" handset circle first and then swipe to the right , towards the small green handset to answer, or to the left towards the small red handset to reject.
I.e. it does not work like most other phones by simply swiping across the screen.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
in ur settings theres a pick up option to answer. im trying this cause i cant answer either.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ness B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 30
전체 시간: 9,957
