주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 게이밍 노트북으로, Nvidia 860M 그래픽 카드와 15.6인치 디스플레이를 탑재했습니다. 2015년에 960M 그래픽으로 업데이트되었습니다.
Can I replace my screen with IPS one?
I bought my laptop with TN matrix display and that everybody know there is very bad colors and angel of view. What type of screen I need to get and replace ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
It's really hard to take screen with different display , neither TN , IPS , or anything like that.
You can do it, but it's really hard as i said because you will have to test a lot of monitors to find the compatible one, even though you will have the right code.This doesn't mean that it will be compatible with your laptop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes you can replace it. There are a lot of tutorial available online. You can find for B156HAN01.2 replacement IPS screen and replace it with your current TN Panel
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thats an AHVA panel not IPS
댓글 달기
As long as the pinout and connector type on the replacement panel matches the old one (a lot of Haswell-present laptops use iDP instead of LVDS now), it’s doable. However, the Y series is harder then most laptops because Lenovo decided to fuse the screen to the glass with UV LOCA glue.
On the Y700, the screen is fused to the glass assembly across the board, but the Y50 *may* be salvageable. However, the problem is if you have a touch screen assembly, it shares the same fused design as the Y700. You’re good if it’s non-touch, but if it’s touch that may be a problem. It does sound like it’s non-touch since you mention it isn’t IPS, so that’s going to work in your favor.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
denizramadanov 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 1,009
