주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 K430T로 식별, 2016년 1월 출시. 스크린 유형은 16M 컬러 IPS LCD 정전식 터치스크린과 13-megapixel 카메라를 장착하고 있습니다.
Power button failing when in the dark?
Just got a LG K10, for some reason if I'm in a dark area the power button/volume buttons become unresponsive. This issue does not exist in well lit environments. Anyone else experiencing this, or does anyone know why this might happen?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I started having this issue ever since I got my screen replaced. I think it's some kind of hardware issue. If I'm in the dark and this happens it's because I have the brightness all the way up. When the brightness is on 0% and I'm in the dark I don't have this issue. So try lowering your brightness. Glad I'm not the only one with this issue
의
댓글 달기
답변 5개
선택된 해법
Performed a factory reset last night, this did not resolve this issue. I will say though I did a little more trouble shooting and I might have figured it out.
I recently put a protective case on the phone that has a tempered glass screen protector. It could be that the tempered glass is somehow triggering the proximity sensor, making the phone think it's next to someone's head. Then with that sensor tripped and little to no light detected the phone thinks it's best to not turn of the screen.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The light sensors may trigger your device .
So the best solution for you before you do anything else,is to factory reset your phone
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
So ,you have figured it out .Great ,happy for you :D
의
댓글 달기
I have the same issue.. Im reading up on this... has to do with the tempered glass everybody recommends remove the tempered glass find a tempered glass with cut out for the sensor by the camera
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This is bs my screen just blackens when the proximity cencor is covered where do i trun this shot of?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
When in the dark area my phone swicth fail to come
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gage 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 10
전체 시간: 2,922
