,how to delete pictures?
How do I delete pictures,etc?
좋은 질문입니까?
You probably have figured it out by now, but per owner manual:
1.) Power ON - flip out screen and find power button on body of camera - the button will light up blue when ON
2.) Press MODE button - immediately underneath direction button circle on back of camera and to the left labeled "MODE"
3.) Use the DIRECTIONAL CIRCLE joystick button above the Mode Button to select PLAYBACK mode
4.) Press down on DIRECTIONAL CIRCLE joystick button for OK to enter the mode - OR - press the PLAY/PAUSE BUTTON (|>) on left bottom side of screen frame
5.) The screen will display any thumbnail index of pictures stored in camera memory. (If no pictures are showing then there are no pictures in camera's memory. ) In this mode press down on DIRECTIONAL CIRCLE joystick button for OK to enter the FULL-SCREEN mode. While in the full-screen mode press MENU button to switch back to index mode. Or, if the zoom ratio is set at 1.0x you can move the directional button DOWN to switch back to thumbnail index mode.
6.) Select picture
7.) Press MENU button and select which option you choose:
이 답변이 도움이 되었나요?
지난 24시간: 7
지난 7일: 8
지난 30일: 19
전체 시간: 805
