주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
''PS2''라고 알려진 이 기기는 2000년 3월 일본에서 Sony가 처음 출시한 6세대 게임기입니다. 미국에서는 같은 해 2000년에 SCPH-30000 모델로 출시되었습니다. 이 기기를 수리하려면 일반적인 도구만 있으면 되지만, 다소 까다로울 수 있습니다.
Browser/System Configuration on PS2
When ever I turn on my PlayStation 2 it pops up a screen that says
Browser
And below it it says
❌ Enter
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 4개
How do I get out of this please
의 공유
When i turn on me ps2 even if games in it or not it says browser and system configuration and the light blue ball that would usually move around on the main screen is not moving
의 공유
Also me bruh
의 공유
The cause that the blue light ball isn't moving, is because the CMOS battery is depleted!
Replacing this one should solve it! If you need any guides, please let me know.
의 공유
댓글 달기
답변 8개
가장 유용한 답변
either you have no disc in the system or it is not reading disc
이 답변이 도움이 되었나요?
점수 3
댓글 달기
If the blue dots stop spinning on your PS2 and just stay in one solid ball then that usually means that the Clock battery in the system has died and will need to be replaced, on the fat models (SCPH-10000/30000/50000) It is usually located on a little board mouted to the left side of the DVD drive if it isn’t thn it will be located on the main board and will require further disassembly, just pop it out and replace with a CR2032 battery with the flat side facing outwards (writing towards you) on the slim models (SCPH-70000-90000) it is slightly different the battery is located in a little dip infront of the DVD assembly and has a little wire plugged in to the console, replace with the same one of if you can’t find one and are handy with a soldering iron (or someone you know) then get a normal CR2032 Coin cell and there are plenty of guides on YouTube showing how to do it. Note once you replace the battery the Date, Time and other things will have to be reconfigured in the system settings.
Liam H.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Your PlayStation 2’s eye is probably wore out. If you call Sony, they might be able to assist you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes I have same problem
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Same here too oh
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My ps2 is showing browser system configuration
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Pas saya menyalakan ps ada tulisan browser/ system configuration
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
nathanielcollins20 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 47
전체 시간: 16,862
