주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D5200은 2410만 화소 DX-포맷 CMOS 이미지 센서를 탑재한 F-마운트 DSLR 카메라입니다. D5200은 최대 6000x4000 해상도를 지원하며 1080p 동영상 촬영이 가능합니다.
Memory card is locked
Suddenly I started getting an error message that that memory card is locked (it's not). Same message no matter what card I put in. Will not reset--format memory care is grayed out.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Slide the white button on the memory card -- amazing works like a charm
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Have you unlocked the memory card itself?
Try to formate the memory card on a laptop and then try to use it
Update (09/09/2016)
Did you format using the correct SD card formatting tool? You can it downloaded from sdcard.org
Or you can try to do a hard reset on your camera.
1. Remove battery, Memory card, and lens for about 30 seconds
2. Reinsert just the lens and the battery, power the camera on
ensure you are using an approved card: Answer Title: Approved SD cards for D5200 Answer Link:https://support.nikonusa.com/app/answers...
3. The camera settings can be restored to default values by holding the "Menu" and "i" buttons down together for more than two seconds
(these buttons are marked by a green dot). The information display turns off briefly while settings are reset.
4. Hit the menu button and select custom setting menu
5. Select "F" for controls and then "F4" labels " Slot empty release lock"
6. Highlight "Enable release"
7. Test camera with no card/ then reinsert the card and try again
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Formatted in the computer just fine, but same message.
의 공유
댓글 달기
답변을 추가하세요
doylecozadd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 7,663
