주요 콘텐츠로 건너뛰기
MacBook Pro 15" display 모델
8256 질문 전체 보기
do you need to apply thermal grease to cpu chips?
Do you need to apply new thermo greese to cpu chips and heat sink rails when replacing logic board? i replaced logic board and everthing works great but just worried i should have applied new thermal greese to cpu chips. thanks
Update
ok no worries thanks for yout help . will def go and do it now.. many thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
No Prob, try Artic Silver 5.
댓글 달기
답변 3개
선택된 답변
Here is our Generic Thermal Paste Guide, which should help you properly apply thermal paste. Doing it right is very important to avoid overheating issue later in your computer's life cycle.
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
댓글 달기
Yes, you should have applied thermal paste to the CPU. I always recommend that Posters replace the original Thermal Paste that is on the CPU being that Apple uses cheap thermal paste, and it is usually applied very poorly.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
+ I use Artic Silver also.
댓글 달기
many thanks, applied artic sliver as deminstrated in thermal paste guide. works so well sceems to run heaps cooler 2. thanks again
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kurt Russell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 4,338
