주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Moto G4 Plus는 Motorola의 Moto G4를 개선한 모델입니다. Moto G4 Plus는 지문 센서, 향상된 메모리 용량, 업그레이드된 후면 카메라를 제공합니다. 모델 번호는 XT1642 및 XT1644입니다.
ghost touch while charging
got a weird problem,phone works perfectly fine with no issues but whenever charge the device, my friend is experiencing ghost touch and severe lags. Unable to control the touch and it works fine when its not under charging. Tried different charger and still the same problem. Anyone experiencing the same problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 9개
Has screen been replaced before? Some aftermarket screens show signs of this.
의 공유
no, almost new phone, i searched and found quite a few people encountered this problem and no solution
의 공유
I have seen this issue a few times, and having only ever been able to tie this issue to the phone receiving too much charge due to an issue some where down the line relating to power. A better charger has rectified this in other phone models but replacing the screen has never solved it for me. It wont effect the phone overall, you just cannot use your phone whilst charging .
의 공유
Then it's a phone design issue. The digitizer circuit is not insulated enough to avoid interference with the charging circuit while charging the phone.
In result it interferes with the touch screen because of the power going through the phone.
As touch screens are capacitive, they detect the change of current from your fingers. So if you put a charging cable that has power going through on top of the screen it will interfere.
I hope that makes sense.
의 공유
you're right, thanks!
의 공유
댓글 4개 더보기
댓글 달기
답변 6개
가장 유용한 답변
I was having the issue also when the charger was not connected. The fix was to turn the brightness down. The issue only occurred at full brightness and if I brought the brightness down while it was happening I could watch the problem stop in real time. Normally leave the brightness at the mid-level, but have had promising results with the adaptive brightness setting too. Going on 2 months without having to deal with the issue, and it had been an everyday problem.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
The brightness thing fixes it 100%
의 공유
This seems to have fixed the ghost touch issues on my Moto g4 also. Thanks!
의 공유
댓글 달기
Waste phone. Some of the problems i noticed in moto g4 plus.
1. Ghost touch issue while charging.
2. Music player start and stop frequently while using Head phone.
3. Heavy battery drain issue.
4. While choosing notification tone for alarm or some thing, it rings with high sounds. But when we received a notification, the sound is too low even the notification tone is full.
5. Over heating issue. During charging as well as video usage
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It's a software problem. Most of times starts to occur after an OTA update. Reinstalling the firmware usually will fix the problem.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have seen this problem when using a non apple charger and with a non (apple)certified cable on an iphone. Could be the same for the Moto.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi i too was having the same problem
When i connect my turbo charger to it then it suddenly acts weird (ghost touches)
So i fixed my problem by using the old phones charger
2nd method is that to ask for refund
이 답변이 도움이 되었나요?
점수 0
댓글 달기
That's weird. But for me my phone is charging on its own. I don't have it plugged it in the wall or anything. It's powered off. And I don't have an app for self charging fake $@$* apps. It's happened twice in the same day...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kaye 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 45
전체 시간: 22,260
