주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D80은 2005년에 출시된 1,020만 화소의 디지털 일안 반사식 카메라입니다. 사진 촬영 및 영상 녹화용으로 설계되었습니다.
Why will my Camera not work
When I start up my camera the LCD screen is blinking with a code saying ER R but the shutter still works
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Usually, on a Nikon D80 with an "err" message that won't go away, the Aperture Control Unit must be repaired or replaced. There is a small switch contact held on by a small plastic rivet in the Aperture Control Unit that tells the electronics module in the camera what phase the camera is in during its cocking cycle. When that small plastic rivet breaks, the camera can't determine where it is in the cycle and just stops and displays the "err" message.
There are 2 ways of fixing the problem, replacing the part with the same weak, plastic-riveted switch contact or taking the Aperture Control Unit apart and replacing the plastic rivet with a small steel screw which can't break again. I've been using the second method for many years now and haven't had a single body experience the same problem again.
Bob Kilbourn
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
so i looked at the control module and i cant seem to find the rivet where in the aperture control module could this rivet be found
의 공유
댓글 달기
답변을 추가하세요
Icepro's 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 38
전체 시간: 2,674
