주요 콘텐츠로 건너뛰기
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
71 질문 전체 보기
Windshield Washer clogged on one side?
I need to get under the plastic cover to take off my windshield sprayer to unclog it. How do I get to it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Take off the weather stripping on the front of the cowl.
Go to driver side reach in the middle an push in on the clip holding the cowl in place. There are 1 or 2 more on each side that you will have to push on to get off both sides. They overlap and I think you start on the drivers side.
Unplug the hoses connected to the nozzles.
Pop out the nozzles (small clips on the sides-push up)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You might try using the garden hose with high pressure, to blow the dirt back inside. Then it might spray normally. You could see if the dirt can make it through the spray nozzle after that.
Or try removing the spray button from a spray can of Windex, and push the top right into the spray nozzle. The high pressure from the can should blow the dirt and any fluid back through the line cleaning it out.
If you can remove the sprayer line somewhere under the hood, you can probably just blow it out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bonnie Atchison 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 7,076
