Strange behaviour after replacing battery
I replaced a bad battery on my iPhone 6. The process went fine, and when finished the phone came on with nearly a full charge. However,
(1) the phone won't charge.
(2) plugging in a lightning cable usually does not cause the phone to charge, but bending the plug a little in the socket will cause the charge indicator to come on.
(3) even when the charge indicator is on, the new battery does not charge.
I'm wondering whether a bad battery may cause these symptoms. I would think it could be a problem with the lightning connector, but the fact that the battery doesn't charge even when it says it should be charging is strange.
Anyone run into this before?
좋은 질문 입니까?
댓글 1개
Ben 의
