주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 LG 안드로이드 기기는 2015년 10월에 출시되었습니다. 이 안내서 작성에 사용된 기기의 모델 번호는 LG-VS990입니다.
I need to replace the glass
I have a LG v10 and I need to replace the glass
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
The glass screen on this phone is repairable, but difficult. You can get it professionally repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
댓글 달기
답변 2개
선택된 해법
Here is a link that should help. Tap or click on the blue link. Good luck.
https://m.youtube.com/watch?v=H5VDlpRFBK...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
The glass is difficult to repair on this phone, but repairable. You can get it repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
댓글 달기
가장 유용한 답변
They sell just the glass online, but I would highly suggest you avoid that. The entire assembly is glued together and there are some very delicate components between the different layers. I was unable to replace just the glass and ended up destroying the whole LCD screen in the process. Your best bet is to buy the whole display digitizer touch screen assembly. They currently run about $150, but most of the videos online about replacing them include the entire assembly, including the one above.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
I dropped my phone and the screen had spider web cracks. Then I just took off the outter screen. It was a pain in the butt but it still works as it did before. Im guessing the outter screen isnt the digitizer?
What did you do to remove the outer screen? Is your phone the V10?
I wish i knew that before i attempted it] not just the v10 but also on the LG stylo 2 plus.dead
댓글 달기
답변을 추가하세요
Luis Milla 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 6,619
