주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
Glass replaced but screen not working now (backlight is)
I've followed the instructions to replace the glass screen perfectly, but now the screen doesn't display anything.
I can see the back light is working when I press the power button, but no picture is actually shown. The ipad mini also acts like its working (will lock and unlock and is detected by itunes)
I have hard reset and restored the software. Any other suggestions?
Thanks in advance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
You may have damaged the LCD/Backlight flex cable when removing it from the frame, or quite possibly damaged the backlight filter on the board. I would first order in a new LCD/backlight from iFixit and test that. If it still doesn't work, it's a board issue.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Would the backlight be working if the cable was damaged?
I saw the posts the the backlight filter solutions, but I presumed that the backlight wouldn't work if this was the issue.
댓글 달기
귀하의 답변을 추가하세요
Will Dawson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 136
