주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Gear S, 모델 번호 SM-R750은 Android 스마트폰과 함께 사용하는 스마트워치입니다. Samsung Gear S는 2014년 10월에 출시되었습니다.
replace Deterriated charge contacts
How to replace charge connector
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Enjoy, In some of the forums people have had success using a conductive circuit writer pen to build charge terminals back up to work good again.
Samsung Gear S replace charge connector, link below shows tear down of watch at which point you will be able to access charge terminals and possibly replace, may have to desolder and solder new.
Check the attached links,instruction and guides, Good luck
Samsung Gear S 배터리/마더보드 교체
https://www.google.ca/search?q=circuit+w...
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Thanks for your help. I ordered the 841-P nickel conductive pen resistivity 1 Ohm by MG Chemicals from Amazon under $15!! Worked great. It set up in about 20 minutes. How ever I let it stand overnight to be sure it was completely dry. This is day one so will be keeping track as to how long this last before I have to re apply. I will use this pen until it is completely gone if need be. Maybe by then I will have gotten my moneys worth out of the watch and can upgrade to something better. Thanks again for your help
의
Love this watch. Ordered the part off ebay going to try and repair.
의
댓글 달기
답변을 추가하세요
enjoy1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 1,147
